Milling Intake?
Milling Intake?
I am sucking oil through the bottom of the intake ports and am pretty sure the intake needs to be milled. When building the motor i was told by a "friend" to just slot the holes and it would be ok Anybody know a formula to know how much to be taken off? i found on one site for every .010 off the heads .0123 off the intake, but wouldnt you have to take block deck height into consideration? I believe my heads were milled .034 and block deck height is 9.016. Im going to the machine shop tomorrow but I like to have a good idea on what needs to be done so im not fed a line.
ill be picking up the intake thursday. seems like i might have diagnosed it wrong. when i pulled the intake i saw oil on the bottom half of the gasket, but the shop owner showed me the gasket was being crushed even and the alignment shouldnt be off enough to cause oil being sucked up through the ports. he wants to hold off on machining the intake and see if its still sucking oil. he did find the plugs on the bottom loose and resealed them; believes this to be the main cause of oil in the intake. also said a couple rocker studs were leaking but not enough to cause the problem.
ill throw the intake on thursday and see how it lines up again. should i mock it up with the intake gaskets or bare?
