starting probelm
Old 02-09-2009, 09:30 PM
z28camaro1090's Avatar
Default starting probelm
I replaced my starter and starter wire.. now when i go to crank the car some times i just hear a loud click from the starter it might happen 10 times then start finally then wont happen for a while then do it again. Ive heard ignition switch, someone told me the key could do it from the chip being old, or neutral safety.. its just a really loud CLICK
Old 02-09-2009, 09:33 PM
Camaro Jearmy's Avatar
try jumping the solenoid with a wire, or screwdriver, if that works every time then keep moving your way back to the ignition switch. really sounds like a bad connection. try putting it in neutral and see if it changes anything.
Old 02-09-2009, 09:41 PM
moderate Z28's Avatar
Does it sound like this - http://www.youtube.com/watch?v=9XI76...e=channel_page
Its the solenoid. Did the new starter come with new solenoid? The problem lies with the main power wire that travels from the starter to the solenoid. I think on the old starters you could fix this problem by turning the stud on the back of the solenoid half way around. Does anyone know what Im talking about?
Old 02-09-2009, 09:56 PM
exactly like that
Old 02-09-2009, 09:58 PM
it was the whole starter i bought .. it was liek 195 dollars
