Need Help With Reading My Datamaster Info
Old 03-11-2009, 11:42 AM
djjab57's Avatar
Question Need Help With Reading My Datamaster Info
well i got a reading before i took it to the shop, didn't drive the car, i will do that tomorrow night after i pick it up. i will post up the info but cant seem to copy it in any way. if you know how to do this let me know so i can. well the right side was running a little lean but believe it is because of the EGR exhaust leak but my main question right now is what is normal for knock count? in open loop i am getting in the 170-280 range. Is this normal i do have a LT4 knock mod if that makes a difference. once i figure out how to post it i will and please check back as i will have more questions im sure thanks
Old 03-11-2009, 02:28 PM
djjab57's Avatar
no one cant help me with this
Old 03-18-2009, 10:45 AM
djjab57's Avatar
whats O2 mV's and should both sides be reading about the same, im getting to way off readings on each side
Old 03-18-2009, 10:47 AM
djjab57's Avatar
one side is @900 the other side stays @ 200
Old 03-19-2009, 11:34 AM
FlamingChicken's Avatar
o2 voltage should be constantly switching from i believe .100 to .900. my numbers could be a bit off but regardless they should be constantly switching from low to high. low voltage is lean and high voltage is rich.
Quick Reply: Need Help With Reading My Datamaster Info
