[F/S] 94 Camaro Z-28 with alot of parts.......
I hate to do it but the Camaro has to go..................
1994 Camaro Z28
Some Videos of the current set-up...........
Click here to see Video
Engine Stuff
1997 LT1 (approximately 120,000)
Royal Purple 5w30 since I have owned it
Moroso CAI
TB Bypass
U/D Pulleys
Electric Water Pump
LT Headers into single bullet muffler
PCMforless tune
Tranny and rear end
4l60E
Shift Kit
Tranny cooler
2800 TCI non-lockup stall
LS1 Driveshaft
373 gears
Suspension and other stuff
V-6 front springs
Poly motor and Tranny mounts
No front sway bar
A/c removed with block off plate
15x3.5 draglites on front
15x8 draglites with 275/50 15 M/T drag radials
SS rear spolier
Parts and mods that come with car
Tubular LCA's
It is a nitrous express plate kit with alot of extras.
MSD 685 box
Moroso Switch panel
Standalone fuel cell
MSD fuel pump
Zex bottle brackets
Custom center hump mount
Blow-down tube
Autometer Nitrous gauge
Zex bottle warmer
2 extra 16in wheels
TH-350 Transmission
3500 Stall
BMR crossmember
Poly torque arm mounts
Filter
Fluid
Strange chromoly driveshaft)
__________________
Probably more I am forgetting
Best Times N/A
12.92 @ 106.77
Info about car
Car is in good shape with lots of new parts. When we put the 97 engine in all fluids were changed, full tune up was done, all hoses replaced with the high performance goodyear ones, new belt, and all new filters throughout. The interior has been guted somewhat. The radio was removed to make way for the moroso switch panel I purchased for the nitrous kit. All speakers are gone aswell. The head liner is currently out of the vehicle but I still have it in good shape.
The Bad
Driver Side window motor is getting weak.
Vehicle surges slightly when idling.
Transmission is hitting rev limiter on the 1 to 2 gear change at WOT. It is fine the rest of the time just WOT is the problem. I believe it is in the tune. I havent talked to them about it yet since I have all the parts for a TH350 swap before the nitrous goes on.
The Price
$4000 OBO
1994 Camaro Z28
Engine Stuff
Moroso CAI
TB Bypass
U/D Pulleys
Electric Water Pump
PCMforless tune
Tranny and rear end
4l60E
Shift Kit
Tranny cooler
LS1 Driveshaft
373 gears
V-6 front springs
No front sway bar
SS rear spolier
Tubular LCA's
MSD 685 box
Moroso Switch panel
MSD fuel pump
Zex bottle brackets
Blow-down tube
Zex bottle warmer
2 extra 16in wheels
TH-350 Transmission
3500 Stall
BMR crossmember
Filter
Fluid
__________________
Best Times N/A
12.92 @ 106.77
Info about car
The Bad
The Price
$4000 OBO
