10 bolt rear end
Old 04-13-2009, 11:59 AM
GreatV8's Avatar
Default 10 bolt rear end
Hey all I'm running the stock 10 bolt and curious to know if the following would do me any good. As of right now I have the T/A cover and 3.73. I understand I have "limited slip"... would putting in a Eaton posi differential and a Detroit Locker do me any good? Or is it a waste of money?
Old 04-13-2009, 12:01 PM
ss.slp.ls1's Avatar
Keep your rear end as it is. Save up for a 9" or 12 bolt.
Old 04-13-2009, 12:07 PM
James Montigny's Avatar
A4 or M6?
I wouldn't put money into swapping the differential if you already have a LSD.
With a cam+Bolt-ons car, the stock rear should do just fine in an A4 ... less so in an M6.
Old 04-13-2009, 12:33 PM
96capricemgr's Avatar
Posi and Limited slip are the same thing.
Posi is short for POSItraction limited slip.
I would keep the stock geared posi over the clutch Eaton, I have found the Eaton clutches to be short lived and the replacement cost to be barely cheaper than new.
Old 04-13-2009, 02:00 PM
My95Z's Avatar
A detroit locker would work great at the strip, but would make the car down right dangerous on the street in the rain. They have a tendancy to lock the axle shafts t/g at bad times (ie going around a turn hard on the gas) sending your rear end right out from under you. The lockers also shock load the axles and I wouldn't want any more stress on the 10 bolt than it already has to take.
The only time I would swap posi units out is if the clutches in the stocker are fried and you are doing the peg leg peel.
Quick Reply: 10 bolt rear end
