LT1 swap question
LT1 swap question
ok well im swapping a 94 z28 lt1 into my 84 corvette. found out i wont be able to run the car unless my VATS is turned off. was looking on ebay and found one of these things and was wondering if this will get rid of the VATS?
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
ok well im swapping a 95 z28 lt1 into my 84 corvette. found out i wont be able to run the car unless my VATS is turned off. was looking on ebay and found one of these things and was wondering if this will get rid of the VATS?
I wouldn't waste your time/money with one of those. You are probably going to want to remove EGR so you'll have to get a tune anyways. Just have it tuned out when you get a tune. Even if you keep EGR, I recommend getting a basic email tune since LT1's run a little rich from the factory tune.
well motor dont fit. gotta get the lt1 corvette front accesories and stuff. oh and gotta get a lt1 vette water pump too
mine is like this:
and i need it to be like this:
mine is like this:
This might work, I had this bracket at one time, actually owned the prototype red a/c delete bracket shown in the pic:
http://www.bowersrodshop.com/info_deletepulley.htm
I'm making my own brackets now because I want a different alternator and power steering pump.
mine has been down 2 years (only driven the car about 2 months the whole time ive owned the car) its on the third motor setup and i dont have anythign else to drive. lost my job and livin off unemployment so yeah.
dunno about spendin $105 on a little bracket like that.
went from this (built up crossfire setup):
to this (built up top end):
to now the LT1:
and bank account at $0
to now the LT1:
You could sell your factory-style a/c delete bracket and put the money towards that $105 bracket kit. What I'm thinking is that bracket will be a lot cheaper than buying LT1-corvette brackets, corvette accessories, corvette power steering hoses, corvette power steering reservoir, and corvette pulley. You also get a new belt with that bracket which probably is worth $20.
yeah im thinkin about it right now. im jsut really not sure if itll work too. i dont have much room in that little area for things. i know that delete pulle yis a little higher then the other one but dunno if itll be high enough. guess ill have to wait for my next unemployment check haha.
