perfect ending to a not so perfect day.
so I got my engine out a few day ago. Ive been spending a few hours a day tearing it down. everything was going smoothly until last night when I didnt have the puller to get the hub off the crank. SO today when I wok up I went and bought the puller(orileys). Got home and none of the bolt fit the threads plus the original bolts wouldnt fit through the slots for the bolts. went to autozone and they looking it up and gave me the puller their system said i needed. Come home and the bolts still didnt fit the holes. I finally found an old puller and some bolt in the garage that fit perfectly(we own a sawmill so we have prolly everybolt ever made LOL). I got everything even and turned it about five 1/4 turns and snap. here is the result.
any ideas on what to do?
if you have access to a welder, try and weld it back on. I had to use a propane torch to get mine off, but it will burn the seal which you should replace anyways
make sure the center bolt holding the crank hub is out also
I think I know exactly what happened. The LT1 crank hub is different than a SBC crank hub. The SBC crank hub has a large hole that slips over the crank snout. The LT1 slips over the crank snout in the same way, however, there is only a small hole in the opening of the crank hub (http://www.shbox.com/1/hub.jpg). You were probably pushing on the hub and pulling on the hub at the same time, that's what snapped it.
What you have to do is get a rod of some kind, I use a 4" brake caliper bolt (something smooth with no threads and long enough to push on the back of the crank bolt hole, similar to this http://www.ecklerscamaro.com/images/wca/720338.jpg), and slip it through the hole in the crank hub, then use a harmonic balancer puller or use a 3 jaw puller and push against that bolt, the hub should come off.
Looks like you need a new crank hub too.
I have a welder in the garage but Im not that well at welding.
The bolt is out. There wasn't one in it. LOL I guess the previous owner removed it and didnt put it back in.
