Overheating.
Old 04-29-2009, 12:51 PM
CharlieSS's Avatar
Default Overheating.
My car overheated today on the freeway. When I hit the brakes it cooled down. On my way up the hill where I live I noticed loss of power and some shaking. Made it to the hill and my water pump was leaking like crazy. Did this cause any damage to the engine? When I start it it still shakes a little bit. Did I blow a head gasket? Will just replacing the pump do the trick?
Old 04-29-2009, 12:58 PM
ss.slp.ls1's Avatar
You need to check both your oil and coolant for signs of the other. Does your car smoke out the exhaust at all. Hopefully you didn't blow a head gasket.
Your sluggish feeling could be the fact that your water pump has leaked water all over you opti. The moisture inside will cause stubling. You might get lucky and your opti will dry out with no damage. BUT, since you have to replace your water pump, if your opti has any decent miles, you might as well replace it along with your water pump.
You can get a new opti from "thepartsladi" on Ebay.
Old 04-29-2009, 10:48 PM
CharlieSS's Avatar
Thank you sir.
Old 04-29-2009, 10:52 PM
itSSlowZ28's Avatar
open the rad cap and make sure your coolant looks normal. then pull your dipstick and do the same. if either looks like some nasty poop you've probably blown a head gasket
Quick Reply: Overheating.
