Do You Have Hesitaion, Stumbeling Under Slight Exceleration ??? Come Inside !!!
Well i did and maybe this will help you a little, I actually had more than one problem and here is what i did to fix it
1. I had a burnt plug wire, it was under the header so it took me a little while to find it and fix it. I replaced it last weekend and that of course helped a lot
2. i noticed that the 2 plugs going to my coil had some exposed wire in them, didn't notice this because it was in part of the wire that had a curve in it, straighten them out and look
3. I sea foamed the car, fuel tank, oil & throttle body. there is a great write up to follow in here somewhere
After each fix it could fill it getting better, now i have no hesitation and have great throttle response. Hope this helps someone having the same issues I was
i still have a slight stumble under mild acceleration. i've replaced my wires and i seafoamed my car a few years ago. i've also replaced the entire ignition system short of the ICM. never thought about checking the coil wiring, i'll have to give it a look
to add to your list of things to do, check all connections! my car had a horrible misfire, and i found a loose fuel injector connection. it was very intermittent and i only found it on coincidence
also double check all your vacuum lines for cracks and make sure they are connected well and all ends
