Need Part Name
Need Part Name
Well tonight I discovered a miss and was messing with the plug wires to get them away from the headers. I was trying to correct a plug wire connetion between the spark plug and the wire itself. I tried getting leverage on this one thing and snapped it.
Description - I was trying to correct the plug second from the front on the driver's side. It's a black/blue colored thing that goes into the block behind the header and it goes into this cream colored thing in the block. Around the cream colored thing is a big nut that it looks like you can twist off.
What is this thing? I didn't drive it after I snapped it off, is it important?
If at all possible could I get a part number because I'm probably going to end going to the stealership tomorrow to get it...
PT728 ECT sensor in head for gauge 12126458
http://shbox.com/1/Parts.htm
Shbox says it's for your gauge. So long as there isn't coolant leaking the car should drive fine with this broken.
