1993 lt1 injectors
1993 lt1 injectors
i need to replace my lt1 injectors for my 93 camaro, what is the original size of this injectors , i think 21 lbs but i am not sure, also where can i get them in tampa- fla.
I thought they were 19# in '93 only...then went up the following years. Just like the MAF and PROM chip...'93 only. I could be wrong on the injector, but I'm pretty sure they are 19# for that year. You can go bigger, you just have to tune for it. Not a real big deal, but it should be mentioned.
19# were used in the 305 tpi cars. 22# were used in the 350 tpi and 92/93 LT1's. After 93 the LT1 got the larger 24# injectors...
If you tried to run a 19# injector on a 350 you run the risk of running them really lean at stock fuel pressures. If you jump the pressure up another 10-15 psi you could do it, but then your almost run out of pulse width at high rpm....
Thanks for clearing that up...I remember it being lower and I knew the 305s had the 19...that's why I had it in my head. I apologize for any confusion. But like duh stated, you can get different injectors than stock size and adjust the fuel pressure and tuning to accommodate them...which was really what I was meaning to get at.
