Where do I fine the least expensive bilt in roll cage?
Old 06-13-2009, 10:09 AM
fuzzyjk's Avatar
Default Where do I fine the least expensive bilt in roll cage?
I guess if I run faster the XX.XX (not sure of the #) I will need a roll cage....do the tracks require a specific cage? I see 4, 6 and 8 point cages, I know I want a bolt in. Which one do I use?
I am gunning for low 11's even though I was told high 10's are poss.
Old 06-13-2009, 10:55 AM
latindragons's Avatar
You should ask this over in Drag Racing Tech. I've mostly heard people using Wolfe roll cages, but they aren't the cheapest things in the world. But here's a rough summary of what is needed at certain E.T's .....
https://ls1tech.com/forums/drag-raci...rness-etc.html
Old 06-13-2009, 12:16 PM
SS MPSTR's Avatar
Don't waste your time with a 4-pt. A 6-pt will really help stiffen the chassis up too.
Old 06-13-2009, 01:40 PM
Z-RATED94's Avatar
Faster than 11.50 and you need a 5-point minimum. I went with the Wolfe CM 6-point bolt in which is welded in a few spots too.
Quick Reply: Where do I fine the least expensive bilt in roll cage?
