First 1/8 mile times...
Old 06-19-2009, 09:26 AM
ss.slp.ls1's Avatar
Default First 1/8 mile times...
Best of the night was a 8.638 @ 87.20 w/ a 2.146 60' time.
Spinning on 315 Goodyear Eagle F1's.
Hopefullly next time out I'll be on some sticky tires.
Old 06-19-2009, 09:47 AM
marc97taws6's Avatar
Those are still some pretty big street tires. Just get some M/T ET Street Radials and get that 60 ft DOWN!
Old 06-19-2009, 11:04 AM
kinglt-1's Avatar
agreed! f1's blow *** for launchin. slap on the m/t's and low 8's will come.
Old 06-19-2009, 11:05 AM
ss.slp.ls1's Avatar
I'm hopping. I think the car has a 8.3 in it...
Old 06-19-2009, 06:03 PM
clwz28's Avatar
You can get a 8.3 easy,I run 275-40 rikens that hook good as long as you dont heat them up to much,I can run 8.3s all day long,and I have low shift points due to the trans,and let off at the end off the track because 3rd wont hold,I know I will be in or right at ths 7s in a couple off weeks when I have my trans built with all the good stuff.You have the mph to be in the 7s,look at my big 83mph due to letting off,and my car is also cam only(cc503) with 135k.
Old 06-19-2009, 06:15 PM
clwz28's Avatar
Sorry ,I just noticed your in CA,your 8.6 is probably a 8.3 down here in east Tx,our sea level is about 1,000 ft.
Old 06-19-2009, 07:24 PM
OddballLt1's Avatar
It sounds like it should go faster than 8.3, ET streets will pick up alot if you can use them to your advantage.
Quick Reply: First 1/8 mile times...
