Installing plugs & wires tomorrow any tips?
Tomorrow mourning I'll start installing AC Delco plugs and MSD 8.5mm wires in my 94 z28. I've read plenty posting about how hard and time comsuming it is to complete this job.
Any advice for me before I go on this journey that will make my life easier?
Take your time, do one plug wire at a time, and the best tool I have found is a short 5/8 spark plug socket combined with a flex head ratcheting wrench that fits the spark plug tool.
These two items have dramatically reduced the time it has taken me to do my plugs. Donations to the swear bucket will increase exponentially. But if you have alot of miles on the plugs/ wires, when done you will definitely feel a difference.
HTH
Andy Schuck
HTH
Andy Schuck
X2
This is a MF to do, but you can get it done. You will find that your body can twist in ways you NEVER thought possible! lmao!!! Are you using a lift??? Might be easier to get to some of the back ones from the bottom...
Do you have headers or the stock manifolds??? If I were you do the OTVC SP Wire mod...makes changing the wires later on a piece of cake compared to the stock way...
X2
Thanks for the tool tip. I'll stop at NAPA in the mourning to get some tools.
Are the MSD wires a good fit? Now im hearing a few of the wires are way too long.
If you have the stock manifolds:
15 minutes - 1 hour on the drivers side (VERY EASY).
1 - 2 hours on the passenger side.
My advice for the passenger side outside of the 5/8" socket andysc is recommending - drop the starter for the back plug and you can reach right up to the plug and wire. The passenger front will require you to take off the alternator.
This all comes from a less than pleasant first experience (lots of scrapes and foul language in the garage that day...) changing my plugs and wires and then having to do it again because I didn't get the back passenger plug wire on and developed a nice miss after a couple hundred miles vibrating the wire loose.
If you had headers, you could practically do the whole job from the top.
Have fun... >
Have fun... >
look up "Made-4-U" and you can get a good set of OTVC SP Wire looms...
Get ahold of 99BlancoSS and he can hook you up with a set of MSD 8.5mm Superconductor SP Wires that ar long enough to go over the covers...
If you already have the MSD Wires maybe he can make a deal with you or something, who knows...no harm in asking...
With the stock manifolds you shouldnt have a problem with the wires hitting the manifold and burning out, but if you ever get headers it is a problem and the OTVC mod alleviates that issue. On top of that it makes changing the wires a HELL of a lot easier the next time you do it...
If you want pics of what the mod looks like, shoot me your email address and I will show you mine.
Tons of useful information thank you guys! One more silly question. My plugs look like there already gaped at .060 but I need them to be at .050. Can you bend the tip to get the correct spec? If so how without cracking center electrode?
On the Pass side, to help with access, remove the short exhaust pipe from the DR side to the Y-pipe, then remove the starter - I had to do that the first time (total time 6.25 hours); the second time I replaced the plugs (and wires as well!) in a bit under 4 hours.
Patience - just keep repeating that word...
WOW! I still have stock manifolds and the last two times i did plugs were 45minutes to an hour tops.1,2,3,5 from the top 4,6,7,8 from the bottom. no taking the starter off or anything ridiculous. i keep seeing posts with people saying it takes hours and hours to do this.
And I mean little too...
they are definately a PITA
What the hell??? You must have some little assed hands or something...I have a hard time getting my hands ANYWHERE NEAR my spark plugs sometimes...hell last time i ALMOST had to pull my passenger side header before I found one little sweet spot lmao.
