Preparing for clutch swap, what to know?
ok, so the clutch in my 95 T/a is shot. im replacing it with a fenco clutch because im broke and it has a lifetime warranty, lol. so i dont want to hear "OH get this clutch" because i already know there are better out there. anyway, im starting to think it would be a good idea to atleast have my flywheel resurfaced so where can i have this done? and what does it cost. and im sure i should have searched but, can i geta link to all the torque specs i'll need when reassembling everything? and any tips or pointers for the whole job, a local guy on here that has done this on his ls1 car many times is going to give me a hand. but still.
Thanks,
Joe
Thanks,
Joe
Thanks,
Joe
Thanks,
Joe
Yes, get your flywheel resurfaced. It should only be like 35 bucks or so. Find a local repair shop and ask them where to go and get it done.
One thing you also need to be sure to do is to replace your pilot bearing/bushing. This will require a special blind bearing tool or a blind bearing puller slide hammer attachment and a slide hammer. I got a blind bearing puller and slide hammer from Autozone. You'll see how to use it.
After you drain the trans and remove the cross member, allow the trans to sag down a little so that you can access the top two trans to bellhousing bolts. You'll need to make the "mega extension" to get them. Basically a bunch of extensions (like a 12" + 6" + 6" + 3") it helps to have a couple swivel head extensions.
I always fill up the trans with 4 quarts, filling at the shifter housing from inside the car, after the trans is all bolted up and level of course.
https://ls1tech.com/forums/lt1-lt4-m...ment-pics.html
Theres a few good pics in there to give you an idea of what's ahead..
I would definatly get the flywheel resurfaced.. It cost me $35 at a local auto parts store with a machine shop
As far as the tourque specs go, I would recomend a Chilton's manual. You can get one from murrays/autozone for about $20. It's got eeeeverything you'll need in there. If you don't feel like getting one just shoot me a PM and I could look em up for you in mine later.
