2002 WS6 Springs on a 95 Z28 make the car higher?
Old 07-08-2009, 01:01 PM
Cross's Avatar
Default 2002 WS6 Springs on a 95 Z28 make the car higher?
When I bought this Camaro awhile back I knew it had suspension swapped to stock's off a 2002 I believe WS6.
I got to see another LTx car and frankly my front looks higher. Would These springs be the cause, why would they sit higher in a car with a motor thats heavier esp up front?
Anyone have a spare set of stock LTx springs or want to swap if this really is the issue?
Old 07-08-2009, 01:09 PM
Internet Mechanic
BlackScreaminMachine's Avatar
At least one of the good thing about WS.6 cars is that you did get higher rated stuff and thicker sway bars, but depending on use and milage they do degrade. How is your stuff?? Do a google search.
Old 07-08-2009, 01:54 PM
ss.slp.ls1's Avatar
If you are going to go through the process of swapping springs...don't waste your time with stock springs. I'd get some of the new BMR fbody 1" lowering springs.
Old 07-08-2009, 02:57 PM
slomarao's Avatar
call sam strano about springs. He will explain all of the companies and his own to you. Each one has their ups and downs.
www.stranoparts.com
Old 07-08-2009, 03:28 PM
Cross's Avatar
NO the car came with them it had QA1 Adjustables I believe that he sold to someone for his stock and cash. The stock swap happened to be WS6 Suspension Pieces.
Quick Reply: 2002 WS6 Springs on a 95 Z28 make the car higher?
