Teflon/rubber rear main seal?
Old 07-20-2009, 10:46 PM
ssbowtie1's Avatar
Default Teflon/rubber rear main seal?
Opinions?
Old 07-21-2009, 01:05 AM
jmd
jmd's Avatar
Never had a problem with Fel-Pro; whatever that is.
Old 07-21-2009, 11:05 AM
95 TA - The Beast's Avatar
Fel-Pro sells BOTH the rubber and the '97-style redesigned Teflon one.
Only use the Teflon one if you can ensure the crank is clean/free from oil and with no 'groove' or lip on the crank surface where it will seal.
The Teflon needs to be installed dry, otherwise it WILL leak.
You cannot use the Teflon with a rear-main repair sleeve.
But, the Teflon has a longer service life and really has no ability to leak if installed properly on a properly prepared and smooth crank.
Thus, if it is an existing application that has rear main leak you are fixing, go with the rubber seal. If it is a new motor/rebuild with everything prepped properly and checked out, go with the Teflon.
If you are fixing a rear main leak, also check to make sure the crank is not scored/grooved. If it is you have two choices, as someone (don't remember who) makes an offset rear main for ones with grooved cranks (basically uses a different area of the crank as the sealing surface), or you can buy a repair sleeve that you press onto the crank with a sealent that will provide a new sealing surface.
Old 07-21-2009, 11:12 AM
ss.slp.ls1's Avatar
Originally Posted by jmd
never had a problem with fel-pro; whatever that is.
^^^+1. My car is '97, so I guess it's Teflon.
Quick Reply: Teflon/rubber rear main seal?
