What lifter are you guys running in you LT1?
Old 07-23-2009, 04:56 PM
WH97Z's Avatar
Default What lifter are you guys running in you LT1?
Just wondering what guys are running for lifters in their cars? Please note if your running a mechanical roller or a hydrolic roller. Thanks
Old 07-23-2009, 05:00 PM
Drift_king2007's Avatar
im just running a factory stock roller lifter in combination with my comp cam(specs in my sig) they seem fine for me... just rocker studs were my issue at first... not anymore. comp studs and shortened molly pushrods... what is your plan for valvetrain?
Old 07-23-2009, 05:03 PM
speed_demon24's Avatar
LS7 lifters here.
Old 07-23-2009, 05:20 PM
Puck's Avatar
OEM style HR COMPs here, switching to GMPP LS7 lifters on the next build.
I had one of the COMPs grenade on my last build, not going to risk it on the next much more expensive setup.
Old 07-23-2009, 05:21 PM
edunegan's Avatar
comp hydraulic roller lifters. 1oo. longer push rods 1.6rr no issue
Old 07-23-2009, 05:23 PM
Badazz 97 TA's Avatar
stock hydraulic rollers.
ss.slp.ls1's Avatar
Stock lifters here with CC503, Comp 1.6 ProMags, and Crane 10308 duals. When the time comes for new lifters, I will get LS7 lifters.
Old 07-23-2009, 05:35 PM
FlamingChicken's Avatar
morel link-bars. had a spider give up the ghost and lost the motor.
Old 07-23-2009, 05:37 PM
airfix's Avatar
LS7's
Old 07-23-2009, 06:09 PM
leadfoot4's Avatar
Comp 875R lifters, a PITA to adjust, with Manley pushrods and GMPP roller rockers.
Old 07-23-2009, 06:10 PM
Z28Camaro30Ann's Avatar
LS7's
Old 07-23-2009, 06:17 PM
96capricemgr's Avatar
stock
but would not hesitate to use LS7s or "caddilac racing" either.
I am sure Morels are great, but with the rpm limitations of the pcm I think the GMPP are all you will ever need and less than half the price.
Old 07-23-2009, 06:39 PM
AChotrod's Avatar
Stock here to!
Old 07-23-2009, 07:38 PM
Wicked94Z's Avatar
been running the old style comp r's for over 17k miles, no problems. pac 1518 spring installed at 1.78 and a real aggresive lobe. have a new crane oem style out of box set ill let go for 100 bucks though.
Old 07-23-2009, 09:05 PM
RamAir95TA's Avatar
Switched from Comp Rs to LS7s.
Old 07-23-2009, 10:47 PM
ADM
ADM's Avatar
Are your heads milled? Whats the length of your pushrods?
Stockers here too, hoping they are still in good shape or will have to replace them with LS7s. Will find out in a weeks time.
Old 07-24-2009, 12:11 AM
myltwon's Avatar
LS7s but in all honestly prolly shouldve stuck with the stockers, they were still good and never gave me problems
Old 07-24-2009, 11:50 AM
ss.slp.ls1's Avatar
No, stock heads, 7.2" chromemoly pushrods.
Old 07-24-2009, 12:47 PM
Whyrun's Avatar
Morrel solid roller's with link bars
Old 07-24-2009, 09:00 PM
Elliott's94Z's Avatar
Originally Posted by speed_demon24
LS7 lifters here.
Same here..
