best piston rings
best piston rings
whats the best piston ring 1/16 ,1/16,3/16 for a 383 with a 225 wet kit, also rod, main, and cam bearings.
As long as they are moly, you should be good. Like mentioned above its more important to get the gap right with that size shot than using a special ring.
For the bearings, what does the rest of the rotating assembly? Most forged cranks require the H series bearing from Clevite, so that would be my pick. Some cranks recommend certain bearings so it would be best to check with the maker.
