**PIC* which tuning cable is this?
I bought it so long a go, I cant remember which one it is. Its for a 94 Z28. Has box with a flip switch on it. Whats it for? I know its a usb cable. I wanna say its a Moates, but hell I have had it a while and dont remember.
Directly from MOATES website:
"The switch on the back of the ALDU1 changes the resistance between pins A and B on the ALDL interface cable. The topmost position places 10k ohms between the pins. Some ECMs require this 10k resistance in order to connect to the ALDL datastream (1227165 is an example). The middle position opens the connection between A and B (infinite resistance). This is the "default" position. Most cars can be datalogged in this position. Cars that require 10k to connect can be switched to this position after connection. The bottom most position shorts the connection (0 ohms). Most GM ECMs dump trouble codes when pins A and B are shorted. This switch position makes doing so simple and convenient when a PC is not available."
Where did you find this, I looked on his site.
