Need help pulling my engine codes!! Jacksonville FL
Old 08-11-2009, 02:26 PM
MattSapp95_T/A's Avatar
Default Need help pulling my engine codes!! Jacksonville FL
I am trying to read the codes on my 95 Trans Am it has the OBD1 computer with an OBD2 plug in.....I am located near Jacksonville FL so if anyone is local and is willing to read it for me I would be very much appreciative!!
I am also looking for a scan master for my car so if anyone has one of them I would be interested in buying that too...
Thanks
Matt
Old 08-11-2009, 03:25 PM
JAKEJR's Avatar
have you tried the paper-clip method? I pull mine using that method, but mine is a 96 LT1. Check shbox.com to see if he shows where to insert the clip.
Jake
West Point ROCKS!
Old 08-11-2009, 03:59 PM
Thanks for the reply!!
Yea the paperclip wont work on mine unfortunately....mine has the 16pin OBD2 plug in and a obd1 computer....
Need some help still>>>>
Old 08-11-2009, 04:00 PM
ss.slp.ls1's Avatar
http://shbox.com/1/xraycable.jpg
Old 08-11-2009, 04:18 PM
Thanks I seen the picture of how to adapt the obd2 to obd1 scan tool....I unfortunately don't have the obd1 scan tool either...I am trying to find a ScanMaster instead of buying a obd1 scanner I was hoping someone local could help me pull the code until i get one...
Thanks
Matt
Old 08-11-2009, 04:23 PM
ss.slp.ls1's Avatar
Thanks
Matt
Do they make a scanmaster for OBD1?
Old 08-11-2009, 04:51 PM
Yes they do
ScanMaster LT1, 1994-1995 OBD1 LT1 F-body, Corvette, Impala SS (Will work on OBD2 LT1's but will not retreive trouble codes.)
I guess that is the route I need to go....
Quick Reply: Need help pulling my engine codes!! Jacksonville FL
