Got oil pressure but another problem
Old 08-22-2009, 11:12 PM
96Formula6spd's Avatar
Default Got oil pressure but another problem
Well got the car back together and started up the engine for the the second time since the rebuild. Anyways finally got some oil pressure at 40 psi when i started it. YAYE only 3 months to finally get that fixed. Any ways the engine was shaking a lot at idle. I think my transmission mount is loose and causing this. So tomorrow I will tighten this up and check the spark plug wires. Anything else I should check. After 6 months the bird lives again.
Old 08-22-2009, 11:21 PM
hitmanws6's Avatar
motor mounts, get some poly mounts if you dont have them
Old 08-23-2009, 08:33 AM
Well checked the mounts and spark plug wires and everything is good. However I think I have a bad battery. Left it on the charger all night. Got up and the charger said 12 volts but none of the dash lights would turn on. I know someone will say to check the grounds but I just did that. What do you guys think?
