Cooling System..
Old 10-15-2009, 01:16 PM
importben's Avatar
Default Cooling System..
Ok so i ran into a problem the other day.. i have a 93 formula with a cooling problem.. well there is a hose that comes from the back of the head which connects to the radiator. it seemed to have broken off so i plugged the radiator and put that hose on the "T" where the bleeder is and placed it where the hose that comes from the throttle body goes on the "T" then blocked off the hoses that go to the throttle body on the opposite side. is this an ok temporary fix? or will it hurt me in someway??
Old 10-15-2009, 02:22 PM
RamAir95TA's Avatar
Sounds like a good time to do the TB bypass. Connect the hose from the head directly to the hose that connects to the other side of the throttle body. You'll pick up a few HP in doing so.
Old 10-16-2009, 12:06 AM
importben's Avatar
any way you can set me up a picture.. im a visual type of person lol..
Old 10-16-2009, 09:58 AM
RamAir95TA's Avatar
Quick Reply: Cooling System..
