Help Engine Noise/tick loud after oil change
I changed my oil tonight to get this noise after I started it up. Its a ticking/clacking sound that seems to be coming from the passenger side.
Before I changed the oil Id get a tick noise when starting the engine cold, but it went away within 30 seconds to a minute.
This noise is fairly loud, I can hear it if I'm sitting at a stop sign. I only really hear it at idle. I havent got under the car to listen to the bottom end yet.
Any ideas?
97 Z28 93k miles
Any ideas?
97 Z28 93k miles
Deff. sounds like rod knock/valvetrain noise. DON'T RUN THE ENGINE ANYMORE!! Check the oil level, if its low (or empty) you either forgot the oil, or didn't tighten down the drain plug or filter. If it's full, you may have had something caught in the filter and clogged up your oil galleys or got some of the plastic protector rap stukk in the oil pump output port. If none of these are the case, your oil is probably bad (i.e. coolant in the oil or poorly produced oil that is waaay too thin and waaay under spec which to be honest is EXTREMELY unlikely)... either that or you had some coincidental major engine failure that just happened to occur at the same time
Oh God I hope its not rod knock.
Well its full of oil that looks clean and fine. I checked out the old oil and there isnt any metal shavings or anything scary in it. I'm pretty serious about my oil changes (German Castrol/Wix or Purolator filter) So I definitely didnt forget the oil or anything like that lol.
I filled the oil filter 3/4 full before I put it on by the way.
The noise isnt super loud but it definitely gets my attention. I drove the car after I changed it (had to) about 24 miles. I can hear the noise at a stop sign at idle in silence(no radio or anything. The car drove and ran fine. Oil pressure is 20psi HOT idle. 40 psi driving 2,000rpm+ 42ish psi cold idle
I just bought this car not even 3 months ago and have put less than 4k miles on it. My last 97 3.8 camaro had a timing chain go in July which led to me cleaning out my bank account for this car.
Okay so get this. I let the car sit overnight and started it up today. And the noise is GONE? I let it idle all the way up until it hit 190 degrees on the temp guage. The oil pressure looks was 44-46 cold start and 23-27 hot idle. There is just normal valvetrain noise no loud ticks/clatter. I didnt drive it I just let it idle about 15 minutes.
royal purple 10w-40 + lucas it made the noise before the oil change....so i went thicker weight and lucas to try and help it....it took a day of sitting and it went away and I parked it before i left for work and it was making noise again
engine restore would be a good investment... but i wouldn't mix it with the lucas...
hell that lucas was as thick as engine honey.....thats wierd how it would thin it out....I will Use some 20w50 if that **** don't stop....It sounded like it was coming from the driverside valve cover....its so feint now it sound like its from the bottom end
and chris97z use thicker weight.....the **** you are putting in there is like supercharger oil
well i haven't heard of lucas thining out.. but if it does then new one on me.. i put royal purple in my motor too... didn't like it.. mobile one 10w-40 now
