Oil leak from the front
The valve cover gaskets had been changed previously because they were Felpro. They didnt use sealant so assuming thats why the back corner was leaking. I used rtv sealant and it's holding up fine now. As I was under the car again today I saw the oil level sensor leaking lol. Fix one find another!
lol I dont mind a little leaking but damn this thing is leaking from every damn seal lol. Car was sitting in a garage for about 6 yrs so I guess it was a shock to the system to be driving again.
Notice the grooves in the hub... I think my car had around 110K at that time. Once I replaced the hub and seal (both new), no more leak. I replaced them during an water pump/opti upgrade.
I have a question about replacing these. I understand about marking the hub to install it the same way it came off but Haynes said to jam the fly wheel so crank wouldn't move. Doesn't it take some effort to manually turn the crank lol? Seems pointless but I'll do it if need be.
