rolling rpms
Old 07-18-2010, 01:43 PM
lethal bird's Avatar
Default rolling rpms
After driving my car's rpm go down to 1k while its still rolling. Is this normal?
Old 07-18-2010, 01:47 PM
Village Troll
SS RRR's Avatar
Need more info.
Old 07-18-2010, 01:50 PM
after any kind of driving while my car is still moving not in gear. 60-40-20 mph the rpms sit at 1200 to 1k. It just all of a sudden started dropping that low
Old 07-18-2010, 03:01 PM
so is this normal.
Old 07-18-2010, 03:05 PM
old93camaro's Avatar
are you trying to say if you put in in neutral at high speeds ( im thinking its a M6) it goes to 1200 to 1k RPM???? if so yes it goes back to the resting RPM's
Old 07-18-2010, 03:10 PM
1badzee's Avatar
lock-up, non lockup? A4? M6? I had a related issue but the opposite. I have a non-lockup th350 and the RPM's used to drop almost instantly to idle (if I let off the throttle while cruising). Now after a new tune, they sort of hover when I let off the throttle (around 1,200 rpms or so). It sounded badass before, camshafting while doing 60mph
Old 07-18-2010, 03:11 PM
yes its an m6 and yes its when i put it in neutral and its at all speeds and it just all of a sudden started doing it is why i was worried about it. it would usually go back to around 1500 to 1800
Old 07-18-2010, 05:21 PM
idformula's Avatar
Mine does that all the time coasting outta gear or with the clutch pushed in.
Quick Reply: rolling rpms
