Cleaning injectors
Old 08-09-2010, 10:30 AM
old93camaro's Avatar
Default Cleaning injectors
Does anyone know a place that you can send in your injectors for bench flow and cleaning? Thanks for you help
Old 08-09-2010, 10:40 AM
Low N Slow's Avatar
http://www.witchhunter.com/
Old 08-09-2010, 10:59 AM
thanks are they pretty good
Old 08-09-2010, 01:42 PM
DAVE00's Avatar
Originally Posted by Low N Slow
+1 - had them do mine about 2 years ago and the quality was great on the new parts and the report on the injectors flow before/after was very thorough.
Old 08-09-2010, 03:32 PM
killagt's Avatar
you use just use redline or chevron techron, or regane fuel system cleaner ? $19 per injector so X 8 is $152 are they foreal ?
Old 08-09-2010, 03:35 PM
DAVE00's Avatar
Man have you ever priced out injector cleaning before? They completely strip down each injector, untrasonic clean them inside and out and then replace all the orings and pintales and caps. Cheaper then buying a set of new injectors especially if you have SVOs.
Old 08-09-2010, 06:14 PM
yes thats the problem i have svo 42lb green tops cost me only 200 but new they are like over 300 so 152 may not be bad. I may try one of the redline or chevron techron, or regane but i think on the passenger side i have a leaking injector my LTerm-LC is around 220-224 and my LTerm-RC is a flat 108 which is low as the pcm will go so thats why i need them flow bench ad cleaned
Quick Reply: Cleaning injectors
