new opti issue?
Old 08-21-2010, 06:27 PM
redhot lt-1's Avatar
Default new opti issue?
i just put a new opti and water pump in a friends 97z. i`ve done a ton of opti`s his was bogging and miss firing under trottle sitting still and mostly on the road. i`ve seen it a hundred times. so i put a new opti and water pump, still doing it.? sitting still it idles fine. recently he had a fuel pump put in and the car has 97000+ miles with only plugs put in. it is throughing codes i just need to get a scanner on it. anybody got any ideas.
Old 08-21-2010, 06:29 PM
LS1 SPEED's Avatar
did you check fuel pressure?
was it a new OEM Opti?
did you replace or check plug wires?
Old 08-21-2010, 08:05 PM
got it from ebay with the water pump but they were both new it was a nice looking on e with the new weather pack plug design.
Old 08-21-2010, 08:09 PM
JAKEJR's Avatar
Spark arcing to ground usually at one of the spark plug wire boots.
Plug wire(s) routed too close to the ICM
Exhaust leak usually upstream of the 02, but not too far downstream can do it too.
I'm assuming nothing's been done under the valve covers before this started.
Jake
Old 08-22-2010, 07:28 PM
well i drove it a few miles today and it has gotten better but stumbles at low rpms i`m going to put the scanner on it in the morning.
