LT1 Custom Build ??'s Computer.....what to do??
Old 09-04-2010, 10:01 AM
LeonbergerG's Avatar
Default LT1 Custom Build ??'s Computer.....what to do??
I Am Building a 95 Trans am. Car Already has Shorty headers Exhaust KN CAI, extreme energy cam, stock heads, 6 spd, Stock Rear, 58mm TB, Now I Am going to bump up the Compression Forged pistons, pink rods, And a 150 shot. what will i need to do to the computer??
what are optoins for Computer software??
Old 09-04-2010, 10:20 AM
RamAir95TA's Avatar
www.pcmforless.com
And I suggest you do some more homework on your build. Sounds like a train wreck to me.
Old 09-04-2010, 10:28 AM
Why a train wreck? I bought the car with the motor broke and now I'm rebuilding it. Got it cheap.
Old 09-04-2010, 04:51 PM
z_speedfreak's Avatar
Ion(madz28) @ www.madtuner.com
Ed Wright @ http://www.fastchip.com/
Solomon @ http://www.lt1pcmtuning.com/
and pcm4less
Those are the big LT1 tuners, I suggest doing some research on them before just picking one, theres not much negative stuff said about MOST of them however I have seen allot of negative comments/bad results from one of those tuners..
Old 09-04-2010, 04:55 PM
1badzee's Avatar
I've had tunes from PCMFORLESS, MadZ28 and Solomon back in the day. From personal experience, all three were great. Solomon had better customer service though.
Old 09-04-2010, 06:20 PM
Yeah I will definitely look into them.
I don't. See this being a train wreck. Other then the rear end might break. But forged pistons good rods balanced and tuned right......what could go wrong ha
Old 09-04-2010, 06:57 PM
BlueRamAir's Avatar
Combination of weak stock parts and mismatched performance parts. Set a goal of exactly want you want to do. research proven combos and talk to engine builders. If you have a HP goal in mind then you know what you need to buy instead of slapping parts on. Ex. Stock rear end is garbage and a 58MM TB is way to big for anything listed in your build.
Old 09-04-2010, 07:45 PM
It will be ok i don't plan on keeping it either. I am just Going to get it running again. Not going to sink a bunch of cash into it.
Old 09-05-2010, 04:57 PM
just picked up a Detroit locker and 4.11 gears for the car. just need axles now and the rera end will be solid.
Old 09-05-2010, 05:41 PM
MattSapp95_T/A's Avatar
4.11 gears in a 10 bolt is far from solid....
especially in a 6spd car....
Old 09-05-2010, 06:59 PM
It will be ok for my project
Quick Reply: LT1 Custom Build ??'s Computer.....what to do??
