70 chevelle swap to a 96 vette lt4 need more horsepowerand install help
I just bought 96 vette lt4 motor and its going into a 70 chevelle and i read they make about 330 hp anyone no what i can do to get more hp and what trans would go with that setup in a chevelle need help like what kind of fuel pump or tank setup,what headers will fit the 70 chevelle on the lt4 motor ,also is the motor mounts the same as a stock 70 350 no extra mods or plates for the lt4 swap
You need headers for the Chevelle with a smallblock, nothing special.
The motor mount bosses are there for your standard mounts BUT if you keep the AC it uses one of the positions and would require you to move the passenger side mount back on the crossmember.
Far as a fuel pump system, you need a bypass system that can supply 45psi.
Far as HP I would sell the LT4s and get a set of ported LT1 heads from www.advancedinduction.com BIG power gains there.
