Ordering guages soon, where should i hook them up to?
If you no longer have AC a lot of trans am guys mount them in the round AC vents in the center....
If that is not an option than Probably a 3 gauge pod for the Pillar would be the easiest and they look nice...
I have my Fuel pressure gauge and Trans temp gauge on my pillar... Fuel gauge is tapped into the shrader valve and the Trans temp gauge taps into the Oil cooler feed line...
Really easy stuff
Matt
Really easy stuff
Matt
MattSapp95, you tapped into the cooler line for your trans temp gauge? was that a typo? i thought you needed to drill into the pan for that, ive got a gauge laying around because i didnt plan on dropping my pan till winter, this sounds way easier
Yea the "best" way to install the Trans temp sending unit is directly in the pan.... However I did not want to drop my new pan and drill into it so the other option is to install a "T" in the Feed line to the cooler and put the sending unit there....the temp variance is small from being in the actual pan....
Just make sure you don't put it on the return side of the cooler or the temps will show much cooler.....
