So my builder recommends a high volume pump
Old 10-02-2010, 05:31 AM
Rob94hawk's Avatar
Default So my builder recommends a high volume pump
We were going over a few last minute details and he recommends a high volume oil pump so I loaded up my Summitracing cart again.
Am I missing anything? Will the new stock oil pan gasket work with the Canton? I really don't want to spend $300 on the Canton but if I have to then so be it.
http://www.summitracing.com/parts/CTR-15-242T/?rtype=10
I'm assuming I can I use the stock pickup with the Melling?
http://www.summitracing.com/parts/MEL-10552/?rtype=10
Also, with the bullet racing cam should I splurge for the composite gear or just stick with the stocker that I pulled out and put aside?
Old 10-02-2010, 05:54 AM
hitmanws6's Avatar
What are you building that needs a HV oil pump?
Old 10-02-2010, 06:16 AM
Rob94hawk's Avatar
block just got rebuilt, LE heads and cam.
Old 10-02-2010, 06:25 AM
wrd1972's Avatar
There are a bunch of HV oil pump skeptics on here. They will certainly chime in.
Old 10-02-2010, 06:47 AM
SpeedDensityZ's Avatar
There definitley is, I ran a Melling HV pump for 5 years without the first issue. My buddy was running the same one and he had all the teeth get sheared off the oil pump drive. Started doing some reading and the culprit was supposedly the oil pump. So, now he runs a basic Melling Select series direct replacement. When I did my new build I used the same pump.
Old 10-02-2010, 07:46 AM
joelster's Avatar
I guess I am one of those skeptics.
It's not that I think high-volume pumps are bad, I just feel they are very unecessary if the motor is built and machined properly. A stock sbc/LT1 oiling system is very effective in stock form.
Old 10-02-2010, 09:12 AM
Village Troll
SS RRR's Avatar
Originally Posted by Rob94hawk
We were going over a few last minute details and he recommends a high volume oil pump...
Did you ask why? No reason to run one unless your bearing clearances are loose. Probably a good idea to investigate this before the engine is together.
Old 10-02-2010, 12:17 PM
BALLSS's Avatar
if your builder is machineing the bearing clearances wider than a HV pump would apply to that build. NOT on a stock motor
as noted under part description:
", providing additional flow to performance engines with wider bearing clearances. "
Old 10-02-2010, 02:16 PM
96capricemgr's Avatar
Or to a motor halfass slapped together without good machining. Sometimes in race applications for very high HP a HV pump might be speced for wide clearances. IMO a LOT of the time though it is done so cheap parts can be used without proper inspection and correction of taper or just sloppy dimensional tolerance.
A HV pump and 20w-50 oil do not need the same small dimensional tolerance as a a standard volume pump and 5w-30.
Old 10-02-2010, 03:34 PM
Rob94hawk's Avatar
Originally Posted by SS RRR
Did you ask why?
No. I did not. I felt there were more important questions to ask like will the air foil really give me 5 hp or 10....
Old 10-02-2010, 03:51 PM
MattSapp95_T/A's Avatar
Yea worrying about an air foil is certainly more important than your oiling system....
5-10hp won't matter when your motor is scuttled......
Old 10-02-2010, 04:05 PM
Rob94hawk's Avatar
Will the blinker fluid mod help?
Old 10-02-2010, 05:49 PM
LSWHO's Avatar
I would say do it since you'll be inside the gas tank. Also make sure you use NEW oil. Used oil has more dirt in it. In this situation used oil is a no-no.
Old 10-03-2010, 07:28 AM
Jcl_96TA's Avatar
Now wait a min! Used oil is just as good, as long as you screen it out first. A spoon full of sand will help seat in the rings too..
Old 10-03-2010, 02:14 PM
Rob94hawk's Avatar
Damn, I forgot to ask him about Zmax or Slick 50? That way I can do the oil pump delete mod.
Old 10-03-2010, 02:22 PM
Village Troll
SS RRR's Avatar
You should. Unless you specifically requested loose tolerances it's retarded to think a high volume pump is necessary.
Old 10-03-2010, 02:29 PM
kinglt-1's Avatar
Prolong FTMW!
Old 10-03-2010, 03:29 PM
brucer's Avatar
the high volume pumps tend to stress the composite oil pump drive assembly causing the gear to fail.. also using a high-volume/high-pressure pump with a stock pan isnt a good idea either..
one of the smarter things i seen done was the use of a high capacity vortec truck pan and a stock gm pump or melling select with a high pressure spring..
if you wanted to, you could use an single plane intake with a distributor hole and a dummy distributor to replace the composite oilpump drive.. you would need an elbow and fuel rails also.. or have your stock intake machined for a distributor hole.
Old 10-04-2010, 05:39 AM
Rob94hawk's Avatar
Got a part number on that melling select Brucer? I've got time. Engine gets delivered this week.
In all seriousness engine is going to be spun to 6700. This was the reasoning behind the HV pump.
Old 10-04-2010, 06:08 AM
lordrazo's Avatar
well im going to run th hv pump my clearances are not tight but also im running canton pan and im using a single plane with a distibuter delete shaft gets rid of that cheap plastic on from factory and i have a turbo setup that needs oil as well so that is why i went with it if your using stock pump drive do not!! use a hv pump it will destroy the plastic on it
Quick Reply: So my builder recommends a high volume pump
