Stock Piston Valve Relief
Old 10-06-2010, 06:40 AM
97pontta's Avatar
Default Stock Piston Valve Relief
I'm putting together a budget LT1 with a stock rebuilt bottom end. What size of valve relief does the stock LT1 piston have? I thought it was -5cc but couldn't find anything to confirm 100%.
Also, what head gaskets are most of you guys using in the .026-.030 thickness range? I was looking to bump the compression a bit by going with a thinner than stock gasket. Also will be running a 226/234 AI cam.
Thanks for the help guys.
Old 10-06-2010, 07:23 AM
RamAir95TA's Avatar
Stock pistons have a -5cc valve relief.
For gaskets you can use OEM Impala head gaskets. They are .028" thick (opposed to .049" for stock).
Quick Reply: Stock Piston Valve Relief
