Need help with ewp install how to remove drive gear
Old 10-07-2010, 02:53 PM
black05stxjt's Avatar
Default Need help with ewp install how to remove drive gear
ok got every thing tore down and the hole in the timing chain cover welded up. I cant figure out how the drive assembly comes out. I removed the 2 bolts securing the plate and lossend the timing chain its self but i cant get the drive to move more than 1/8 any suggestions???
Old 10-07-2010, 04:26 PM
95z28onjuice's Avatar
well for starters the cam gear is in the way. once you remve it then you can press or knock the back side of the wp gear out of place. it will be in there good and tight, you may need to remove the intake if it wont come out to gain access to the rear
Old 10-07-2010, 04:29 PM
sweetbmxrider's Avatar
hammer and punch from the lifter valley side. cam gear has to come off.
Old 10-07-2010, 05:09 PM
finally got it like yall stated the cam gear didnt have to come all the way off but almost to the end of the dowl. thanks for the input guys
Quick Reply: Need help with ewp install how to remove drive gear
