patriot valve stem seal
Old 10-08-2010, 07:57 PM
merim123's Avatar
Default patriot valve stem seal
quick question guys...
My valves are 11/32 and guides are .530.
The valve stem seal that's part of the 8401-bsbc kit is .562 internal diameter when I measure it with calipers. It slides right on top of the valve guide and spins freely. I'm going to assume this is wrong and that I need a valve seal with an I.D. of .530 like these...
it should fit really snug on the guide, correct?
http://www.jegs.com/i/Manley/660/24045-8/10002/-1
Old 10-08-2010, 08:00 PM
wrd1972's Avatar
Patriot is notoriuous for packing the wrong seals in their kits. Call Gunner at Patriot and he will fix you up with the right seals. Seals should require light tapping from a socket when being installed.
