What do you guys think about this for 1k
Ok ive been looking for a engine what do you guys think about this for 1 grand. I've posted this on another fourm but wanted some more input on it.
eagle nodular iron crank 3.750",5.7 gm pink rods,keith black .60 over pistons,hasting racing rings,clevitte 77 racing bearings,lt4 hydrolic roller lifters,lt4 cam off 96 vette (not the hotcam)comp cam double springs,milidon full windage tray aka diamond stripper,melling high volume pump with mlidon pick up tube, 7 qt stroker pan,gm performane timing set,cloyes double roller chain,alluminum underdrive pulley, alluminum keyed crank hub,arp rod bolts,arp cam bolts,arp main stud kit,arp head bolts, arp oil pan stud kit,pacesetter long tubes with copper gaskets,ported and descreened maf,g2 fuel pressure regulator adjustable, thats all I could think of I'll also throw in a more agressive comp cam 305
That's the same crank I broke with 450rwhp all motor.
https://ls1tech.com/forums/lt1-lt4-m...read-more.html
sounds like a stock motor .060 over.....plus there is a lot of misleading info....."gm performance timing set, cloyes double roller," plus the cc305 is the more aggressive cam?? Sounds like too much money to me.....and at .060 there is potentially no more room for a rebuild if need be...
