f-body wheel hub
f-body wheel hub
someone jammed a rotor on the passenger side and i had to knock out the studs in order for the rotor to come off. i cant drive the studs back in straight with out the hub off the car> i thought 4 bolts in the backside held it on but it would not come off. so does it come off as just the hubb itself or do i have to take that whole assembley off of the control arm?
Village Troll
It is only held on with four bolts. I recently took mine off and ruined both of them due to having to hammer them out. Depending on how long the hubs have been on the steering knuckles, the hub is in a very harsh environment so you are having to deal with rust/corrosion. Mine were the original so they felt like they were welded on.
Have you tried putting a stock lug nut on the stud to draw it in?
