How do i eliminate the starter lockout?
get the resistance of the chip in the key, then go to radio shack and get resistor with the same resistance. Solder that to the little 22 ga. wires running out of the steering column. that should cure the issue if it's in the switch or column. Personally I'd call one of the mail order guys and just have them delete the VATS out of the PCM. That'll cure all issues....
You have to remove the relay that is located behind the glovebox. The attach the two larger wire that's lead into the relay. Don't quote me on that completely since it has been a while since I did mine. But I am sure of the relay part and location, just not the wire part.
Background:
http://shbox.com/1/pass_key.html
How to get the resistor value:
http://shbox.com/1/4th_gen_tech2.html#pass_key
Diagram:
http://shbox.com/1/vats_bypass.jpg
Diagram:
