Fuel Rail Covers and EVAP question
I've been thinking about getting some FRC's to clean up the LT1. However, I have a 97, so there's that extra EVAP sensor. #11 here, for those of you that don't know what I'm talking about:
I'm in CA, so the EVAP system has to stay. So, my question is this: Is there any way to make all that EVAP stuff fit under the FRC's? Anyone done it? I don't see why I can't relocate it, if needed. How are the 96 Vettes set up? Thanks for any input.
remove the bracket & tuck valve against intake manifold. "corvette" FRC fit just fine. you will need to drill or notch the DS FRC for the fuel lines. you will need to dress the wire loom & vacum lines tight between valve cover & intake manifold.
