Steam pipe/flow question
So the_merv had replaced the metal line and banjo bolts with brass fittings and fuel line. The only problem was that on the passenger head the fitting was right over the farthest back intake bolt. I could turn this fitting 90 degrees to prevent this when I re-install, but then I wonder, will the coolant still flow that goes through there?
