Have to remove heads, so can I reuse new head gaskets after I just torqued them down
Old 12-12-2010, 07:59 AM
djm_e22's Avatar
Default Have to remove heads, so can I reuse new head gaskets after I just torqued them down
Long story short, I just torqued my new heads and new felpro 1074 gaskets down yesterday with arp studs, but now I need to pull the heads back off to check something. Am I going to be able to reuse these head gaskets and arp studs?
Old 12-12-2010, 08:18 AM
SoxXpupPeT's Avatar
I dont see why not? Aslong as the head gaskets in good shape, there shouldnt be any problems with it. the studs are just studs... aslong as there arent any threads missing, youll be fine
Old 12-12-2010, 09:37 AM
ElkySS's Avatar
i wouldnt risk it
Old 12-12-2010, 10:02 AM
RamAir95TA's Avatar
Do not reuse them. Gaskets seal by crushing. Once they are compressed and conform to the heads/block, they're done. Two things you shouldn't reuse are condoms and head gaskets.
Old 12-12-2010, 10:05 AM
MattSapp95_T/A's Avatar
NO do NOT reuse the head gasket....Once they have been torqued that is it...
ARP studs however can be used over and over....
Old 12-12-2010, 10:26 AM
robsquikz28's Avatar
YOu will only hear that in Jersey shore Lmao Joe...
Do NOT reuse them, you are fucked in other words. Time to buy some new ones
Old 12-12-2010, 10:51 AM
Spiers's Avatar
^I dont think the cast of Jersey Shore would have any idea what a head gasket is
Old 12-12-2010, 05:24 PM
defaultexistence's Avatar
jesus,seriously? ....NO to reusing the head gaskets
Old 12-12-2010, 05:26 PM
1961ba427's Avatar
I have heard that it is okay to use the MLS style head gaskets, but I never have and I'd be afraid to risk it. It's just not worth the small price of new ones.
Old 12-12-2010, 05:46 PM
joelster's Avatar
They haven't gone through any heat cycles yet. I would reuse them. How do you think shops check ptv clearance? They use the exact parts going into a build and torque the heads down to measure the clearance. Then they unbolt them and check.
Old 12-12-2010, 05:47 PM
RamAir95TA's Avatar
I'd be surprised if you could even remove them without damaging them.
Old 12-12-2010, 06:03 PM
fergymoto's Avatar
As long as they don't tear when you remove them I wouldn't be afraid to reuse them. The motor has not been fired and they have only been on a couple days.
Old 12-12-2010, 06:18 PM
curacaoz28's Avatar
Seeing the cast from jershey shore i doubt ther can even refill the windshield cleaner reservior.
On the head gastek depends on the condition when your remove the head. hope it does not break
Old 12-12-2010, 06:21 PM
I8ASaleen's Avatar
I wouldn't risk it, but in today's economic climate why not...
Old 12-12-2010, 07:03 PM
pro94lt's Avatar
Regardless if it's ok or a bad idea, it will always be in the back of your mind, that alone is reason to get a new gasket.
Old 12-13-2010, 10:40 AM
AChotrod's Avatar
I decided to check my PVC and used my gaskets. I called Lloyd to make sure it would be ok first. He said as long as I hadnt run the car it would be fine. Like Jolster said thats what shops do to check PVC.
Old 12-13-2010, 11:10 AM
quik95lt1's Avatar
if they are metal shim gaskets/cometics go for it........as for a laminate like fel pro there is no way in hell i would re-use them whether they ran or not.......for the 39.95 just by a new one
Old 12-13-2010, 11:17 AM
fergymoto's Avatar
On a paper gasket like a 1074 it will be fine.
On something like a Mr Gasket 5716, Victor Reinz, stock replacement Felpro, etc (graphite sheet) once you bolt it on the material from both sides of the steel shim will come off. One side sticks to the head and the other to the block.
Same deal with MLS gaskets, the sealing adhesive will stick to the block and heads.
Old 12-13-2010, 11:22 AM
1961ba427's Avatar
I always used old used gaskets (of the targeted compressed thickness) for checking ptv clearance. I never knew anyone used new ones. I'm not trying to say they don't/shouldn't....just didn't know.
Old 12-13-2010, 11:35 AM
Burning Rubber's Avatar
I re used mine I have the same gaskets. I sprayed the copper coat on them though.
Quick Reply: Have to remove heads, so can I reuse new head gaskets after I just torqued them down
