BBK 58mm problem
Old 12-27-2010, 06:03 PM
brettmc's Avatar
Default BBK 58mm problem
The throttle blade pivot has some play in it and I'm thinking it's not controlling the throttle blades properly. Whenever I clutch to shift or come to a stop the idle won't come down but I can blip the throttle and it will idle down. Is there a way to fix this as in braze or screw the arms together so they pivot the same? The press fit looks like it's real loose and needs to be tightened. Any suggestions?
Old 12-27-2010, 06:06 PM
Wicked94Z's Avatar
I tried screwing them together, but that developed play as well. Just have someone TIG it.
Old 12-27-2010, 06:11 PM
brettmc's Avatar
I was told one of the arms was a cheapass metal and would melt when subjected to a welder.
Old 12-27-2010, 07:02 PM
NewOrleansLT1's Avatar
You need a new one.
Old 12-27-2010, 07:24 PM
old93camaro's Avatar
I was having the same problem before i put the car in storage, i have the Holley 58mm and i put a return spring on it to help it a little but i think im just going to replace mine as well. I had the idle problem while coming to a stop and if you just smash the gas it would have like a second delay and that's not good when you have over 400rwhp.. so yea i would just buy another TB and try not to get another BBK i had a problem with them with split BLM
Old 12-27-2010, 08:45 PM
Wicked94Z's Avatar
That's cool what you heard, but I posted what I know from experience Welding works fine.
Old 12-28-2010, 08:52 AM
brettmc's Avatar
I guess the plan will be to get it welded if the only other option is a new one. I'll give that a shot and buy another TB if it doesn't work. Thanks for the help folks!
Old 12-28-2010, 09:06 AM
wrd1972's Avatar
Mine did the same thing as well as countless others on the board.
When the TB blades are sealing 100% of the air, you get that sticking condition like you described. Crack the blades slightly open with the adjusting screw and the problem will be gone. You still want the vast majority of the idle air going throught the IAC circuit.
Old 12-28-2010, 02:17 PM
brettmc's Avatar
In case welding does not work and I'm forced to shop TBs...what 58mm brand seems to deliver the best performance for the buck?
Old 12-28-2010, 06:52 PM
Wicked94Z's Avatar
it's not a sticking condition, it's play in the shaft and cable "bracket"
Old 12-28-2010, 07:20 PM
RamAir95TA's Avatar
They are all the same for the most part. I splooged for the Holley mostly because it's the best looking throttle body out there (well, except maybe for the AS&M mono!).
Old 12-28-2010, 07:37 PM
moderate Z28's Avatar
I had nothing but trouble back when I had a BBK 52mm. I sold it as quick as I could and put the 48 back on. But I want to get a stock one bored to 52mm like that guy sells on Ebay.
Old 12-28-2010, 09:48 PM
brettmc's Avatar
That Holley looks damn good. How is it holding it up to street driving?
brettmc's Avatar
Summit Racing has a Summit branded 58 mm that about 60 less than the others. Any info on that?
Old 12-29-2010, 03:58 AM
fex77k's Avatar
I had to throw a tack on the cable arm brackets. Really poor design but I haven't had any problems with it since.
Old 12-29-2010, 06:10 AM
wrd1972's Avatar
Rumor has it, its a Trick Flow TB.
Old 12-29-2010, 06:12 AM
wrd1972's Avatar
Do you have a pic you can show of this?
Old 12-29-2010, 08:15 AM
fex77k's Avatar
Here I found some pictures of it.
Its not pretty but it works.
Old 12-29-2010, 08:17 AM
wrd1972's Avatar
Second pic is not loading for me. Something about a gateway timeout.
Old 12-29-2010, 08:21 AM
quik95lt1's Avatar
my holley 58mm did this when i had it on my car.....i just cleaned up the edges of the throttle blades and it fixed it.......apparently all these tb makers dont have very good machining tolerances........some work fine and some dont
Quick Reply: BBK 58mm problem
