Possibly a bad opti spark or igniton?
Okay this only happens once in a while, sometimes when im in reverse and trying to turn my car would just die, but I would turn the car back on fine but like I said this only happens when im in reverse.
Any suggestions?
Any suggestions?
I just visual check all the vacuum hoses. If something looks questionable I spray a little brake clean on the questionable area while the engine is running. If the idle goes up or down, you found your leak.
Good point riceburner, check you fuel pressure as well.
Ill look into it, ill try to fix it asap before it gets worst
