FAST Computers
FAST Computers
Beside the computer and harness what else does it take to install a
FAST computer.Is it stand alone or can you run the stock computer
for transmission and gauges.
The FAST system is a full standalone, you would need to piggyback the stock PCM to retain the factory gauges and control the automatic trans if equipped if not running a stand alone TCM. FAST makes a plug and play kit for LT1/4 engines.
yep^ horsepower connection out of washington makes a harness to interface as well that i used with good luck...........i just got rid of my stock harness and ecm cause all it was doing was running my tach and speedo.........the xfi is a great system......and the speedo can be retrofitted with a unit from dakota digital........
