OTVC plug wires
Old 02-03-2011, 07:26 AM
Miller95z28's Avatar
Default OTVC plug wires
were do i find them for lt1 camaro?
links?
thanks
Old 02-03-2011, 07:34 AM
bigj2717's Avatar
Thunder racing sells a kit with everything you need to make them.
Old 02-03-2011, 08:00 AM
RGSS's Avatar
Made for you has two different setups I have used:
These that are held from the valve cover bolts:
And these that are bolted to aluminum brackets from the side of the head:
The wires will have to be cut to fit. You can use MSD or Moroso for example.
I prefer the second type because you can remove your valve covers without having to worry about the spark plug wires.
Some aftermarket heads dont have the threaded holes on the sides, though.
Old 02-03-2011, 06:48 PM
96TransAmboosted's Avatar
the 2nd one are very nice,
Old 02-03-2011, 08:47 PM
Tbird232ci's Avatar
I bought the kit from Thunder Racing, and I'm not sure if it's my fault, quality, or just wear and tear, or anything of the sort, but I have had them on my car for about 2 years, and they're arching by the opti. I haven't had much time to investigate, but it's something to keep in mind.
