Nitrous Timing Retard using MSD Optispark Distributor?
Old 02-09-2011, 12:49 PM
Rumblin70ss's Avatar
Default Nitrous Timing Retard using MSD Optispark Distributor?
Hey guys,
Just wanted some input on this.......
Looking for a way to retard the timing when I add nitrous to my car in the next few weeks. I was originally looking at adding an MSD or Mallory ignition box to do it, but could I just use the MSD Optispark's adjustable timing to perform the same function? Max NOS would be a 150 shot.
I already have the distributor so it wouldn't cost me anything to do it. The car is out of state having a motor put in and NOS installed. If I could save the extra expense of the ignition box and install, it would probabaly save $500.00.
I can always put it in myself at a later date when it comes home.
Thanks for any input.
Old 02-09-2011, 01:09 PM
96capricemgr's Avatar
The timing adjuster is not a reliable piece though and you would need to fab a pointer and degree the damper which would pretty much also mandate a keyed hub. To do that well you will spend what you would on a Mallory box.
Just do the Mallory box and then you have the window switch and spark based rev limiters which are huge engine safeties.
Old 02-09-2011, 01:30 PM
THADD's Avatar
Agreed!!! I am using the Mallory($290) and it is worth every penny.
Old 02-09-2011, 04:02 PM
fex77k's Avatar
Agreed adjusting the MSD Opti is a pain in the ***.
I run a Dig 6 box that has 2 rpm limits(stage and max) and a NX retard.
Old 02-10-2011, 07:58 AM
Thanks for the input guys, looks like I will be buying an ignition box after all.
Old 02-10-2011, 08:03 AM
pancho toco loco's Avatar
When you guys run the Mallory box do you have a NA tune and use the box to retard or are you running a No2 tune?
Old 02-13-2011, 01:29 PM
From my research, it looks like I will use a N/A tune and use the box to retard the timing for the N2O.
Quick Reply: Nitrous Timing Retard using MSD Optispark Distributor?
