fuel lines
Old 02-20-2011, 10:35 PM
fastredlt1's Avatar
Default fuel lines
So im doing the fuel and wire relocation on my 95 TA. Two things, do i need the 3rd fuel line and where can i get the rubber grommets for the holes im going to cut???
Old 02-20-2011, 11:20 PM
Puck's Avatar
There are only two actual fuel lines, the third is to the EVAP canister and can be deleted and plugged off if you wanted to for some reason.
Rubber grommets can be found in the HELP section of most auto parts stores, and you could also probably get something that would work dirt cheap from Home Depot or Lowes.
Old 02-21-2011, 12:19 PM
AChotrod's Avatar
I got grommets in the Help section of Advanced Auto. I also deleted the EVAP solenoid and put a small specter filter on the end of the hard line where the plastic lines hook up under the car.
