Vacuum leak
Vacuum leak
So I pulled the intake to fix the oil leak that I had coming from the front of the motor, in doing so I replaced the intake and the 58mm TB, I also put block off plates in, now the car won’t idle and it backfires though the intake. Tried unplugging the MAF and the car goes to 5,000rpm and holds, next I did the carb cleaner in the TB it seem to finally find an idle, any ideas were the leak is?
