Optispark vacuum lines, can i make my own?
Old 03-28-2011, 12:50 AM
GR33N GoblinM6's Avatar
Default Optispark vacuum lines, can i make my own?
Ok i HAVE the vacuum line that has the 2 little diaphrams.. im missing the one vacuum line that goes from the intake elbow to the opti.. i really dont want to spend $70 on ebay for those lines..
anyone make their own? Anyone know what size that little blue 90* hard plastic fitting is than goes into the elbow?
Old 03-28-2011, 02:13 AM
jester1614's Avatar
bring the blue fitting with you to an auto parts store and get matching hose, thats the easiest way if you have the fitting that is
Old 03-28-2011, 01:17 PM
TIIMuch's Avatar
I need to make a set from scratch, anyone have an idea where you can find those check valves/filters,...what ARE those, anyone know?
Jeff
Old 03-28-2011, 01:45 PM
litch2004's Avatar
IIRC there isn't a valve, filter, or diaphragm in that line. Just got to a parts store buy an assorted set of fitting for a pew bucks and I think its like 1/16 or 1/4 id tubing.
Old 03-28-2011, 01:55 PM
MattSLONOMO's Avatar
just replace the hose as stated or if you want the whole thing..
try gm partsdirect..
http://www.gmpartsdirect.com/
I bought 2 back in 2009..they were around $35 with shipping then.
vacuum harness I think was the term..
this is the part number from shoe box's online stuff..that's the best resource I've ever found..
http://shbox.com/1/Parts.htm
1995-1997 Optispark vent and vacuum harness
# 12555323
I've never found the blue diffusers anywhere seperately..but someone
may know..
their purpose is to slow down the air so it's not a direct vacuum leak..
Old 03-28-2011, 02:23 PM
yeah i have those check vavles.. and that particular vacuum line.. the line i need is the one with the 90* blue fitting that goes into the intake elbow.. it just looks like a 5/32 vacuum line with the blue fitting..
Quick Reply: Optispark vacuum lines, can i make my own?
