SA rockers with Chromemoly Pushrods
I was wondering if it is good to run Chromemoly Pushrods with SA rocker arms; I know I can't run guide plates but what about Chromemoly Pushrods. I am thinking about running these with my comp promag 1.6 SA rockers http://www.trickflow.com/egnsearch.a...115+4294779030
yes, good to replace weak stockers.just make sure you get the right size..also keep in mind you are in the danger zone on your stock valve springs.. they are weak from milage and not designed for the 1.6 RR's but will work...channge them at the same time as RR's ..heres a good replacement...
http://www.alexsparts.com/products/C...%26-Cups..html
full list has pushrods too ... http://www.alexsparts.com/categories...2C-GEN-II-SBC/
.. then SPARY IT!
.. then SPARY IT!
That's why I have le1 heads with sprigs that are more than good enough for my hotcam and 1.6 SA rockers. I already have the SA rockers so I am just going to reuse them and install the stronger pushrods. I just need to measure the length because my stock ones were too long; should be 7.1 or 7.15. I already made a solid lifter I just need to pick up my comp measuring tool on Tuesday.
